What Needs To be Fixed In ProDemand
Re: What Needs To be Fixed In ProDemand
Okay, so to get to those items, you'd have to go through this:
2004 Dodge 3500
Here is another it does not say if this is front or rear ring and pinion.
- mitch error.JPG (37.62 KiB) Viewed 47787 times
Same; sub-category [boxed in red] confirms Front or Rear for the items that follow once you select:
Mine does not do that. It goes like this on my end. For the 2011 F350.
- mitch error.JPG (23.01 KiB) Viewed 47784 times
- mitch error 2.JPG (65.95 KiB) Viewed 47784 times
Here is the 2004 Dodge
- mitch error.JPG (71.3 KiB) Viewed 47781 times
Okay, had to go back to another PC with SE 7.2.9 to see what you're seeing. So when you get SE 7.3.x in a few weeks it has the views I've shown above.
I Have Found Since My Last Post That On demand Is A Lot Better. Still Would Like to Print A Larger Wiring Diagram. Thanks
When attempting to print a wiring diagram, I select the full page and it shows the print preview image on the screen as a Black & White image with a check mark that has to be removed each time if I would like to print in color. I would like to set the default to Color and avoid having to un-check each diagram for color printing.
Thanks for posting; inquiry made.himels wrote: I would like to set the default to Color and avoid having to un-check each diagram for color printing.
Here is the response regarding printing question:
"We created the current experience because people complained about the cost of color ink cartridges."
Who would want to print a color wiring diagram in black & white loltimbre4 wrote:Here is the response regarding printing question:
I know, but you'd be amazed how many calls we got.sbebenelli wrote:Who would want to print a color wiring diagram in black & white loltimbre4 wrote:Here is the response regarding printing question:
Maybe make it a sticky setting so that users can choose one and never have to change it? I too find it annoying that I have to uncheck that box EVERY time.
If it was a desktop app, it would be pretty simple. I believe the printing attribute in a browser is problematic or we'd have that option. I did hear that it *might* be possible to discern what type of document and print appropriately. (thinking B/W for repair info + color for diagrams as example)ricmorin wrote:Maybe make it a sticky setting so that users can choose one and never have to change it? I too find it annoying that I have to uncheck that box EVERY time.
I had a feeling. If it's a one page diagram I pull it up on the 32 inch screen.
Multi page diagrams are a different story.
I'm the same way. I have a 32" at my tool box. I would rather look at a wiring diagram on that than a small piece of paper.
- IMG_0933_5_15.jpg (83.09 KiB) Viewed 46256 times
