Sublet
brianrex
Sublet
Post by brianrex »
When sublet is calculated it ends up being added to the labor totals. How can i get it into its own category so it doesn't skew the labor totals? Sublet is usually freight , machine shop costs , fuel etc. and i don't want it in labor. It would be nice if it ended up being listed on the posted orders report.
ShopManTim
200 Club: Major Contributor
Re: Sublet
Post by ShopManTim »
I am agreed. And I would like to be able to get a report on sublet cost and income also.
brianrex
Re: Sublet
Post by brianrex »
I need it to NOT be included with the labor totals
Re: Sublet
ShopManTim wrote:
Wed Oct 07, 2020 11:58 am
There are two sublet reports under the Management tab. One is detailed and the other is not. Shows cost and profit. These are date rangeable.
brianrex
Re: Sublet
Post by brianrex »
Why does the sublet add to the Labor total and not unto its own? To get the true labor total you have to back the sublet out and recalculate it.
Re: Sublet
brianrex wrote:
Wed Oct 07, 2020 1:45 pm
I can only speculate, but I think it originates from when most sublet work was machine shop stuff. That is labor mostly from someone else; valve job, resurface heads, etc. Today it takes on a whole new meaning.
Re: Sublet
Are you wanting something like this??
If so I can TRY to tell you how i set ours up. This is for towing
brianrex
Re: Sublet
Post by brianrex »
yes, as long as i will be able to break it down at the end of the day and it wont go into the labor total.
brianrex
Re: Sublet
Post by brianrex »
If you could help with the way the account classes are set up based on your GL codes would be so helpful !!
I truly appreciate the help
Re: Sublet
Be warned! I know NOTHING about how GL codes effect ANY export, IE - excel or any other accounting software!!!!
I went into
Set up
Standard tables
Then I used the "ADD" button and added "Towing" and made the GL code something not already used....appears I picked 40100
I also made one for "parts at cost" and used 40300
On the invoice it does show "sublet" but does NOT show if it is towing or any other type of "sublet". Just as my "parts at cost" still show as normal parts on the invoice, however, it does break it out in the report I use at the end of the day. (see screen shot above)
The report i use:
Reports
Accounting
Revenue by GL code.
brianrex
Re: Sublet
Post by brianrex »
I see when you double click on those codes there is a sub category for those is there any need to do anything there ?
Re: Sublet
Can I call you?
