Manager SE 8.2.2 Release - Adds 2021 Models
As promised, we've made an interim update available here: http://m1faqs.com/fix/SE/version/Manage ... .2.113.exe
It contains a few minor fixes, but functions primarily to update the YMM list. Clicking the link above will trigger the downloading of the SE 8.2.2 release.
Please note this as an interim release this is not the customary automatic notify shops delivery and requires users to actively seek it out and download to install. All of this DMV model data will be included in the full SE 8.3 release that will be distributed to all users in our usual fashion.
Re: Manager SE 8.2.2 Release - Adds 2021 Models
Is there a README available for the minor fixes?
If you click on What's New In This Release from the home splash screen, it's been updated with SE 8.2.2 details.
- rhillig
Thank you, Thank you, Thank you for this update!!
For some reason the link will not work for me
I use chrome and it would not allow it to work. I tried edge and it worked.
- Vehicle YMM list updated
Message Center updated to highlight the most recent message
- Location Column will now display on PO Worksheet for all intended catalogs
Late Fee Assessment will no longer continue to prompt when dismissed
Status Mapping will not prevent access to appointment editor
Program Security for Part Kit editing has been fixed
Batch Payments – On Account payments will now correctly show in History
Odd. You've used manual updates from the site before I assume. Do you recall having this trouble in the past?sbebenelli wrote: ↑Fri Mar 26, 2021 8:33 amI use chrome and it would not allow it to work. I tried edge and it worked.
Yes it has always worked. I just tried it again and when I click on link it does nothing. When I copy link and paste it into address bar the page will not open. This is when using chrome.Silky7 wrote: ↑Fri Mar 26, 2021 8:52 amOdd. You've used manual updates from the site before I assume. Do you recall having this trouble in the past?sbebenelli wrote: ↑Fri Mar 26, 2021 8:33 amI use chrome and it would not allow it to work. I tried edge and it worked.
I can access that link using Chrome. I get a warning from my virus software regarding executables, but I can and did get the file. Perhaps your security software is blocking?
Yes, but this is after you apply the update, correct?
Correct. The short update list was also copied here a few posts prior to this one.
For some reason, I can not apply the update. The link works, it lets me do the initial download, then it says it can not find the specified file. This has been happening for the past several updates and I have to call tech support to have them install the update manually. Not sure why that is happening.
Larry Jackson
Greg's Too Car Care
Fort Smith, AR
Greg's Too Car Care
Fort Smith, AR
Thanks for reporting this. I actually saw the same issue, but no one else could reproduce it. I think it has something to do with longstanding temp files on machines that have been doing manual updates for long time, but didn't have the opportunity to confirm that.DynaBMan wrote: ↑Wed Mar 31, 2021 3:56 amFor some reason, I can not apply the update. The link works, it lets me do the initial download, then it says it can not find the specified file. This has been happening for the past several updates and I have to call tech support to have them install the update manually. Not sure why that is happening.
Is there anything I can do to fix the issue? Or is it strictly a support issue?Silky7 wrote: ↑Wed Mar 31, 2021 8:04 amThanks for reporting this. I actually saw the same issue, but no one else could reproduce it. I think it has something to do with longstanding temp files on machines that have been doing manual updates for long time, but didn't have the opportunity to confirm that.DynaBMan wrote: ↑Wed Mar 31, 2021 3:56 amFor some reason, I can not apply the update. The link works, it lets me do the initial download, then it says it can not find the specified file. This has been happening for the past several updates and I have to call tech support to have them install the update manually. Not sure why that is happening.
Larry Jackson
Greg's Too Car Care
Fort Smith, AR
Greg's Too Car Care
Fort Smith, AR
Not that I've found yet, Larry. I'll let you know if I do.
Thanks, Dan. I will call support when I get the free time.
Larry Jackson
Greg's Too Car Care
Fort Smith, AR
Greg's Too Car Care
Fort Smith, AR
Just a fare warning for those running Quickbooks Integrator.. We had this update done last Friday and it broke our integrator and rendered however it was previously syncing incompatible. We were told to contact "Back Office", whoever that is, to get some Accounting Link software installed. Did that, but they can't install until this coming Friday, which we're closed, which puts it at next Thursday. No bueno. We're dead in the water in the accounting department until then. No mention at the time of upgrading Teamworks of "oh, by the way, it's going to kill your Quickbooks integrator." Now we're dealing with a huge mess and the owner is some kind of livid.
Silky, if you're out there, can you help??
