1998 Olds 88 - Lean With P0171
santiago
Post by santiago »
[some help please]
I have a 1998 Olds 88 and I have a lean condition PO171. I replaced intake gasket, repaired exhaust leak, replaced both O2 sensors, replace thermostat, flash ECM and I still have the same code.
Re: 98 olds 88
Hey! Welcome to the Forum. If you share as much info as possible on the issue yer havin, you'll be findin help from various ones of us.
On the car ; didnt they have some mass air flow issues? Or perhaps there is unmetered air getting into the system - a leaking air intake tube. Have seen that already.
Re: 98 olds 88
Why did you replace those items? Just for the code or ?
Re: 1998 Olds 88 - Lean With P0171
i'm not absolutely sure here but i believe these intakes would develop leaks in the egr port causing this issue.
fortknoxx
Post by fortknoxx »
was this one of the buggers that have an updated (screen) egr gasket? what was the engine size?
fortknoxx
Post by fortknoxx »
any news?
fortknoxx wrote:any news?
Email sent 3/29/10
Hello,
Thanks for joining the forum, it works pretty fast. You already have three replies with suggestions or requests for further information:
http://managerforum.net/viewtopic.php?f=35&t=6423
Tim
Return to “GM Cars”
