Lube Sticker Pro Settings & More...
Oil change sticker software & printers
MRISICH
200 Club: Major Contributor
Post by MRISICH »
Setting Up Lube Sticker Pro:
LSP - Customize1
LSP - Customize1
Here you choose the label that will be displayed on the application for the type of Oil that you put in the vehicle. You also choose the tolerances for that oil. Additional settings below are to help calculate the next appointment date based on vehicle usage.
LSP - Customize2
LSP - Customize2
Here the user has the settings for the application automation; what phrase the application will add to the vehicle recommendation, and which category that recommendation will be assigned to.
Another very important setting, is what days of the week the shop is open or, what days of the week the shop wants to accept appointments. If you select that the shop is not open on Sunday, that automated procedure will not set a future appointment on Sunday.
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
MRISICH
Re: Lube Sticker Pro Settings & More...
Post by MRISICH »
Lube Sticker Pro:
Main Screen User Interface, once the user assigns all of the application settings this is the main screen that user will use day to day. All the user will need to do is open this screen, choose the oil used and then click Print
LSP - Main Screen
LSP - Main Screen
Depending on which printer you purchase, below is how the sticker will look like when the user clicks Print
LSP - Sticker Output
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
MRISICH
Post by MRISICH »
Latest Release of Lube Sticker Pro; now includes the Bolt On Community which allows users to supply OE intervals for both Normal and Severe driving patterns. This will now allow our user community to assist one another by publishing the OE guidelines per vehicle. Once the vehicle data has been submitted the information will be available for all to use.
[img]
Lube Sticker Pro Main Screen
[/img]
- Another major update with Lube Sticker Pro; is now it remembers last used option, so the next time the application opens for this specific vehicle it will remember last interval used.
[img]
OE Community Intervals
[/img]
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
NSM
Post by NSM »
I was told the Dymo sticker printer (priced at $99) pretty much requires the use of a razor blade to remove the stickers from the windshield. Can you confirm this? The static cling printer you offer is too pricey at $435. I wish your software was compatible with my Cobra Systems, Stryker lube sticker printer (static cling).
Yes they dont peel off easily i use it and its apain in the butt i wish i woulda bought the static cling i was talked out of it by the salesman they said the static clngs are a pain to set up? no experience there.
I actually love the adhesive style stickers......they NEVER fall off. Sometimes up here in the cold it's difficult to get a static sticker to stay put.
Really what type do you use?
1000 Club: Interstellar
Post by Pauls Automotive »
I use the adhesive type to. They aren't to sticky you can get them off. The static cling ones never worked well for me. I get my through oilchangesticker.com
Last edited by Pauls Automotive on Thu Dec 13, 2012 9:57 am, edited 1 time in total.
[email protected]
MRISICH
Post by MRISICH »
I have heard that shops are leaving the first sticker on and putting the next on top of the first one to help with the fading.
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
MRISICH wrote:I have heard that shops are leaving the first sticker on and putting the next on top of the first one to help with the fading.
We tried that. The problem with that is if you don't get the sticker exactly on top of the first one it makes the printing really hard to read outside with the sun shining through it......gives this weird doubling effect. Plus it looks messy and wreaks havoc with my OCD. They scrape off fairly easy anyhow. :oops:
I agree i couldnt stack them doesnt look good i just deal with the razor blade and achohal to remove adhesive.
MRISICH
Post by MRISICH »
Latest version of Lube Sticker Pro, now supports another label printer the Brother QL-580N
Lube Sticker Pro and Brother QL 580N
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
MRISICH
Post by MRISICH »
Lube Sticker Pro - Now supports Holidays and "Closed" dates.
- The latest version of the software (version 2.0.25) in the settings tab will allow you to plug in the days that shop will be closed, then Lube Sticker Pro will not schedule any appointments on those dates!
Lube Sticker Pro and Holidays and Days Closed
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
MRISICH
Post by MRISICH »
Lube Sticker Pro - New Update has new feature!
Now you can tell the software how many appointments max per day and how many minutes to space the appointments apart!
Lube Sticker Pro - Max Appointments
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
MRISICH
Post by MRISICH »
Lube Sticker Pro - Now is multilingual; you can now set up the application so that you can read the content in a language that you choose. This is the start of a number of language enhancements that will be coming out with in the Pro Pack modules. Simply go into the settings tab and choose the language that you want to the user interface to display in.
Lube Sticker Pro - Multi Language
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
MRISICH
Post by MRISICH »
Lube Sticker Pro today now has the ability to also print professional key tag labels. This new feature was just released on the latest software now available.
Lube Sticker Pro and Key Tag
Lube Sticker Pro and Print Key Tag
Lube Sticker Pro and Key Tag Settings
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
ARS
Post by ARS »
What do you mean by Key Tag? So there is another printer to print that? Not sure what this is all about?
MRISICH
Post by MRISICH »
Hi ARS:
- You can get another Dymo; or purchase a Dymo that handles two media types and now print professional looking key tags when you customer comes in. I would recommend a second print media, since regular labels are less expensive than the labels used for the windshield.
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
MRISICH
Post by MRISICH »
Lube Sticker Pro, now when you want to tell the system that you are closed on holidays (like Christmas) you can then select recurring.
Lube Sticker Pro - Schedule Days off
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
MRISICH
Post by MRISICH »
Did you know, that in the latest lube sticker settings you can now dictate how lube sticker pro populates your future appointments?
Step 1. Open Lube Sticker Pro
Step 2. Click on Settings
Step 3. Click on Automation
Step 4. Pick the start time that the first appointment should be made
Step 5. Choose the max number of appointments for any one day
Step 6. Choose the minutes between appointments
Step 7. Click the save button
Lube Sticker Pro - Auto Appointment Settings
From that point forward when you click the print button to print a lube sticker; the automation of appointment setting will reflect your settings.
Michael Risich
Founder & CEO
BOLT ON TECHNOLOGY™
Return to “Lube Sticker Pro”
