2010 Lincoln MKS Subframe Labor Time
I have a 2010 Lincoln MKS 3.5 VIN 1LNHL9FT7AG613074 that I need the labor time to replace the front subframe. I couldn't find it and assume this might be more of a body shop item.
Re: 2010 Lincoln MKS Subframe Labor Time
I have a labor time of 3.5 for what is called a front cross-member.
Thank you. Are you using ProDemand? I can't seem to find it.
I did not look in ProDemand.
OK thanks again
