Water Pumps With Timing Belt Jobs?
434MONTECARLO
Post by 434MONTECARLO »
It would be very helpful to include water pumps as an add to timing belt jobs since most of the timing belts are now done at 100,000+ mile intervals.
KGA
Re: Water Pumps With Timing Belt Jobs?
Post by KGA »
Usually if we are doing a water pump with a timing belt the water pump labour has the timing belt combination labour underneath it. Not sure if this helps.
This is an editorial question regarding Estimator labor practices so I have moved this to ProDemand.
Return to “Using ProDemand”
