2001 Ford F250 SD 7.3L - Wire Question
- nickscarcare
I have this truck here, I pulled the rookie mistake and misplaced where this wire goes. To many long days with I guess. I think it goes from the turbo y pipe post that I have in the picture to a ground on the intake cover head, which is the last pic. Bolt is in lower right corner of pic.
- 1215142144.jpg1.jpg (239.14 KiB) Viewed 9849 times
- 1215142058.jpg1.jpg (148.13 KiB) Viewed 9849 times
- 1215142059.jpg1.jpg (181.28 KiB) Viewed 9849 times
Re: 2001 F250 SD 7.3
The first picture is the intake pressure switch I think. Looking at the wire I'm thinking it's a power feed since it's insulated that way. Possibly a lead off of the glow plug relay's. I don't have a 7.3 in the shop right now but a tow service I use has one. If they show up here I'll have a look. Does it feed off of the alternator? It may come off of the stud on the alternator to a feed, possibly to the glow plug relay.
- nickscarcare
It does not feed off the alternator, I know that. This is what happens when you take something apart and come back to it 5 days later, without proper marking! Memory loss as I get older also.
- liljoe
The best I remember that wire is the ground wire for the intake heater. It goes a stud on the drivers side, I think.
- liljoe
That wire goes on the stud of the intake heater first then a ceramic insulator then the power wire form the relay with the nut made on it.
I am fairly certain that is correct.....
- nickscarcare
Re: 2001 Ford F250 SD 7.3L - Wire Question
That is what I was thinking and it would make sense, but I don't like melting wires if I don't have to.
- liljoe
yeah, I kinda hate to lose the factory smoke too!!!!
