6.5.54 Low Inventory By Part
We lost the part locations on this report with this update. I'll copy .49 report over for now. FYI.
Re: 6.5.54 Low Inventory By Part
Thanks, I will let them know to restore it.
Ric,
When you get a chance, let us know if that worked. Logically, it shouldn't. That report hasn't undergone any recent template changes. The little number in the far bottom right should still be LowInvtryPartNo .rpt 11.09.06 which is quite old.
*Edit* I don't actually see locations listed on this report in 6.4, or 5.9 even. Am I looking at the right one? Under Inventory, Low Inventory By Part Number?
You have the correct report.
You're right, it didn't work. But I assure you that locations were present in that report on 6.5.49. I was very happy to see that change.
When I went in to swap the report, the date of the new one was 1-2015, so I'm fairly sure it has been updated.
Here is the folder AFTER the swap. The original report had the same 2015 date as the others.
I think I know what happened. According to the changelog, that report was SUPPOSED to be available since 6.5.40. It wasn't. I think I may have gotten the corrected file from JD or TIM.
My memory is getting bad.
No worries. I'm finding it more and more difficult to keep up with all these moving pieces.
I found the report on my thumb drive and moved to my computer. It now works. Ooops.
You guys should really distribute that report. I mean it IS on the changelog. LOL.
