2010 Ford E350 Decode?
1000 Club: Interstellar
Post by Pauls Automotive »
1FDNE3BL1ADA47155 won't decode for some reason
Re: 2010 Ford E350 Decode?
This does decode on the SE 6.6.7 release as follows:
That is odd. This is what I get when I hit decode.
Paul,
I'm thinking you're on an earlier version of Manager? 6.5.x? Tim stated this decodes on 6.6.7.
Ric you are absolutely right. My mistake.
liljoe
Post by liljoe »
I think that if you start with a blank vehicle screen, nothing selected, it will decode that. That message is different then the one that says it cant be decoded.
You may be right. I'm thinking it may have something to do with it being a ford truck to. I recently had my database mported back into SE from Enterprise. I have to decode all my vehicles again. This is the only one that has had a problem but also the only Ford Van. I will try a few other and see.
liljoe
Post by liljoe »
When I get this, I just go to the year and click it then backspace and tab. It will ask if I am changing vehicles and I click yes then decode the VIN.
My data base was imported from TRACS, I used to get this a lot, but not so much now that most of the vehicles have cycled through the system since then.
Thanks for the suggestion Lil Joe. I tried that but it didn't work. I went so far as to delete every piece of vehicle day and then save it that way. When I pulled the vehicle back up to reenter the info all I had deleted was still there.
Return to “VIN Decode”
