2011 VW Routan - 3.6L Eng SE Timing Gears?
- 200 Club: Major Contributor
Does anyone have any info on how to replace the timing gears on this van. I cant find any thing on it in mitchell or online...
Re: 2011 VW Routan - 3.6L Eng SE Timing Gears?
If you can't find it in ProDemand, call content support and they will get the info for you.
FWIW, I looked and couldn't find it.
I pulled the van in and scanned it for my self found a p0340 code. Still could not pull anything up. Did a check on the internet and found people saying then they had this done under warranty back when there vans had like 20000 on it. Did find out then it is the same motor as a T/C 3.6 2011. Found out to do the gears u have to have the timing chain tools for that motor witch do not have.... So going to call and let them know then we just cant do it...
