I can power the window up and down with a power probe. The rear module is not powering the window when activated with either the rear key switch or the front switch. I assume it is due to the code, however SI states that manual operation with the front switch should be possible, but it is not.
Note that the code is hard and appears before the window is activated. I've had this code with Toyota's before where the motor bumps a little then sets the code. Not so in this case.
The latch works fine and pulls in electrically as it should. The two state switches on the latch appear to change as expected.
It would seem that I'm down to a module failure or something in the sense circuits on the window motor, but it seems a little too coincidental that the window stopped working after the latch replacement. There was some prying and light banging on the door to get it open, but nothing crazy. Maybe enough to damage one or the other?
I obtained an identical vehicle and compared data pids. All appear as the same. I swapped the module with no change. I got a used window motor with no change. I retested the wiring between the module and the motor, all good. The wiper shows that it is in park. I cannot activate it because the module shows the window open.
I'm running out of ideas.
