- Snap of Vehicle List when Scheduling..PNG (14.15 KiB) Viewed 3104 times
Vehicle Selection When Creating Appointment
Please see above. Very often when creating an appointment, the vehicle selection screen will open and the first to columns (plate and state) will be over-sized and the remaining columns are squished closed so that you can't see year or make. Why?
JAY PHILLIPS
Re: Vehicle Selection When Creating Appointment
Jay,
Please see the bottom part of this post. http://www.managerforum.net/viewtopic.php?f=233&t=12237
I am set up as a user and yes the view will be fine after I change it, but it seems like after a restart, it goes back to the way I showed before.
JAY PHILLIPS
Close all the stations first, to make sure the user profile is only open on one computer. Setup the screen the way you want under that user, then close it on the host as well. Afterwards you should be set on all stations using that profile.
