2016 VW GOLF (Canada)
3VW217AUXGM042065 No VIN Decode
Re: 2016 VW GOLF (Canada)
It does decode in SE 7.1.2 and likely in 6.6.14. What version of Manager SE are you using? (Lower right corner of screen)
As a test, you can always try the VIN Decode in ProDemand as that is updated more frequently. I noticed the VW VIN decodes there then asks you to select trim level. In Manager SE it expresses this with a list of four to choose from.
- vwvin.png (8.51 KiB) Viewed 9881 times
- liljoe
Tried it in 6.6.14 and it does not work......
Thanks, I stand corrected.liljoe wrote:Tried it in 6.6.14 and it does not work......
