Tire Report for Physical Inventory
It's physical inventory time for tires. In the past we used to go into Inventory, select Wheels & Tires for the Category, increase the limit results, and select print. However, doing so does not print the tire size. I believe this was raised as an issue last year since we made corrections and entered tires properly. As of last year we entered the proper data in Part Number, Description, Price and Size. Now the Size doesn't print on the report which is essential to a physical inventory. Perhaps there's a better report for Wheel & Tires?
Re: Tire Report for Physical Inventory
I looked through and I didn't see any reports from Mitchell that include tire size. If you have Report Pro by Bolt-On, they have a great report called Tire Count Sheet that is exactly what you are looking for.
Tire Count Sheet by Bolt On example
We do not have Report Pro by Bolt-On. I would think that since we entered the data we should be able to report on it as well.
@Mitchell1 - can you assist/advise as this is getting to be a pressing issue.
I sent a batch file that will report that data to excel. We are going to fix/append this report and others with tire specific data,. It's high on my list.
Regards,
John
Johnny5 wrote:I sent a batch file that will report that data to excel. We are going to fix/append this report and others with tire specific data,. It's high on my list.
Regards,
John
Any update on this one?
Report modifications are scheduled to be worked hopefully on Q1, in the meantime do you need help with the batch file I sent?
Johnny5 wrote:Report modifications are scheduled to be worked hopefully on Q1, in the meantime do you need help with the batch file I sent?
The batch file doesn't appear to be working at all. I tried from both a client and the host.
: updated file sent to user :
