Parts Location Labels On Avery 8160 Labels?
Bryce418
Post by Bryce418 »
is there a way to get the part location report to print on a 8160 label? the 5095 labels will not work well with my parts bins.
Re: Parts Location Labels On Avery 8160 Labels?
Bryce, easy ....
Shut Manager down at the workstation you want to print the labels from. Download this file from : https://www.dropbox.com/s/adqfkwfr72xyv ... l.exe?dl=0 .
Once downloaded run it. Open Manager and test the report by selecting the "Part Location Labels, Laser..." YOU DO NEED TO SAVE THIS FILE ONCE DOWNLOADED. AFTER YOUR NEXT UPDATE YOU WILL NEED TO RUN IT AGAIN. ULTIMATELY WE WILL INCLUDE AS AN OPTION IN THE REPORT MENU.
I am not 100% sure about spacing so do a test print and get back with me. Please note technical support cannot help with this file, if you have a problem report back here and we will try to help via the forum. Cheers
Bryce418
Post by Bryce418 »
thank you, I'll se if I can avoid making a mess of that!
Be advised that you won't get a new selection. This replaces the 5095 choice. Thanks, JD.
I've been creating my own labels using the Dymo software that came with my printer. I don't need the location actually on the label. Presumably you are AT the location. :roll: But I do need barcodes so we can scan parts into orders with tablets. Perhaps in the future barcodes can be added to the label?
part label with barcode
